Starting Problem 1995 T100
So I've done a lot of reading, and done a lot of things, but after about 4 months or so I keep having the same starting problem.
It's the one click starting problem where you hear the solenoid click but the truck won't start. Keep trying and it will start.
First I cleaned the battery contacts and checked wires. This made me think I fixed it as it ran for 2-3 months no problem.
Then it hapenned again and I pulled out the starter and replaced the solenoid contacts. I thought for sure that was it as the old contacts looked bad but 3 months later same problem.
Then I replaced the battery, that was Oct 2007, almost 6 months ago. Ran like a charm. Now I have the problem again. (Edit: this time it seems even weirder where I can turn the key, hear the click, and keep holding the key turned for up to 5 seconds or so until it starts. The whole time during this it is silent, not trying to turn over, just sitting there until wham it starts like nothing is wrong)
So what's next, I've read:
- replace starter relay
- rebuild starter and solenoid
- replace neutral grounding switch
Any advice welcome. So many people say the contacts fixed their problem but for me it didn't last.
Reason: more info
