Old 05-01-2008, 03:10 AM
RisingSun's Avatar
RisingSun RisingSun is offline
RisingSun's Photo Albums
Last Online: 08-14-2008 12:00 PM
RisingSun is on a distinguished road.
Default Re: Viper 5701 LE Responder
Originally Posted by Toxarch View Post
I found the Viper online for $245 and the Clifford for $265. After seeing that price and the quotes above, I think I am going to install it myself. They claim it's an easier install than other alarms.
I'll look for those pictures posted tomorrow.
Good luck on doing your own install. Mine was done at a professional shop where I had my JVC head unit system installed. They are an authorized dealer and it took the tech quite a few hours to do the install. He also used a new bit writer that is needed for the 5701. This allowed the oem alarm to be fully integrated in with the Viper system. You do not need a valet key in a box for the 5701. It recognizes the Tundra ecm on its own. There was also alot of misleading info on Toyotas end about which green wire on the ignition switch as there are 4 of them and they all read ignition. Finally had to remove the steering column to confirm the wire off the tumbler. Plus the ecm wiring was confusing as well. It was the very first 5701 my shop has installed due it being such a new item from Viper.
Having an authorized shop do the install ensures the warranty on the system. Again with tax it was $529.38 exactly and tax here in Maryland is 6%. I have a sensor on the tonneau cover, all doors, hood switch, tilt sensor and glass break sensor. With the dark tint it was advised not to do the prox sensor. $800 seems outrageous and you should check around at another authorized Viper installer.
$250 or so online is right but that is without tilt, glass break, prox or any of the optional sensors. The sensors ballpark around $25 or so each.
Good Luck
5.7 Crewmax SR5 4x4 Silver Sky Metallic
TRD Wheels
Undercover Hard Tonneau
Carriage Works Polished Billet Grill
Spray in Liner
Westin Tube Steps
KC 35w Amber Fog Lamps
Weathertech Visors
Sirius Satellite
Flowmaster 50 SUV Dumped
JVC KW-AVX810 Head
Kicker 12" Sub
Boston Acoustic Speakers
Boyo Rear Camera
Extreme Amp
Putco LED Dome Lights
Chrome Door Handles
60" Fire and Ice rear LED lights
Recon 62" Side Running Lights
Viper 5701 LE Alarm and Remote Start
(all sensors except proximity)
Truxxx 3/1 Lift
Xenon H11 8000K HID Lights
** Sunroof being added soon
