Re: Knocking/tapping noise driver side front.
I have the same issue when cold. It almost sounds like the engine is knocking, but it's not since it's coming from within the cabin. Anyway, I went ahead and got under my truck and did some adjustments. Come to find out 3 of the 4 cab to frame mounts were loose. Hmm. I do some mild off-roading and figured it was time to tighten things down. Anyway, I haven't experienced it since, but it's also been a bit warmer lately.
The cab to frame mounts should be torqued down quite a bit. I checked the tight one, and it was over 92 ft-lbs.
2005 Tacoma Double Cab V6 4x4 w/ TRD Off-Road pkg., Auto
1991 MR2 V6 (1MZFE)
