05-05-2008, 04:42 PM
Re: Turning off vsc COMPLETELY...2008 Tundras
Originally Posted by TOMMYDAWGG76
Some might know this, and some might not. When you hold your VSC button down for three seconds, it turns off the atrac, and vsc.. but turns on the auto lsd. If you hold it down again for 3 more seconds, it turns EVERYTHING off, so you have a fully manual mode. It got frustrating turnig off the vsc button, only to have it come on when the truck sensed ANY body roll. My truck was always lowering the rpms when I tried to take off, or if the road was bumpy. Anyways, just a little info in case you wanted to peel the tires from time to time....or even do a fishtail once in a while. Hope this helps, if you already knew this.....sorry i wasted your time. Unfortunately, this only works on the 2008 model from what I understand....
Tommy
I tried it and WOW its fun! But when I turned everythging off and got on the interstate the truck would not shift past 4th gear, I had to do it manualy. It did not matter what position the shifter was in either.
