Old 05-07-2008, 05:50 PM
shall36's Avatar
shall36 shall36 is offline
shall36's Photo Albums
Last Online: 10-05-2008 08:43 AM
shall36 is on a distinguished road.
Default Trans Cooler FSM Excerpt
By request, here's what the FSM has to say about the first gen Tundra trans cooler.
Some of you may be faced with having to replace the OEM unit on an older first-gen truck. Your choices are to buy a new OEM unit (probably a dealer-only item), buy a used OEM unit off ebay or the junkyard (just make sure to flush it well), or buy an aftermarket unit.
My $.02 is that some of the better aftermarket units will allow you to mount a big cooler without over-cooling the trans. These bypass units will only use one or two rows when the fluid is cool and more rows open up when the fluid starts to heat up. For way less $$$, you get more cooling capacity than the OEM unit. The only downside is that the mounting is not a simple three bolt affair. All that said, mounting an aftermarket universal unit is easily done and not suboptimal relative to the OEM setup (IMO).
http://www.daveramsey.com/
Must See Video: Drive Free Cars for Life
