Re: TRD V8 Supercharger only 6psi?
The TRD Supercharger is a postive displacement supercharger. The impellers are turned at a fixed ratio to engine speed. Under ideal conditions the boost should remain constant at the same throttle position.
When your airbox was closed the loss of manifold pressure shows that the airbox was becoming restrictive as airflow increases.
Gadget
