Old 05-09-2008, 09:37 AM
LGL002's Avatar
LGL002 LGL002 is offline
LGL002's Photo Gallery LGL002's Photo Albums
Last Online: Yesterday 10:21 AM
LGL002 is on a distinguished road.
Default Re: Nav antenna placement
Originally Posted by LGL002 View Post
Thought I'd better update my older post after moving both of my antennas from my roof to the under dash location. After a lot of thought I figured I'd rather lose some reception than advertise that the truck had both a satellite and nav system on board. I realize that all one would have to do is look inside the cab to see what's there but at least from a drive by a shopper it wouldn't wave a flag. I did lose some signal strength on both systems but so far all I've seen is the satellite radio signal will drop out more quickly going under overpasses and the nav unit signal hasn't yet. It's only been a week since the move and I'll update this post if things deteriorate.
Larry
PS: I did put a 2"x 2" ferrous metal plate under each one to anchor them.
Another antenna location update May 2008. I recently returned home (MN) from a round trip to CA and NV and found that the under dash Navigation antenna had no reception problems at all. My satellite Sirius radio did have drop out problems quite frequently depending on vehicle direction and which region I was in. It seemed like if the satellite angle was toward the rear of the truck I would loose my signal until my travel direction changed which was at times 20 to 30 minutes of watching the acquiring signal display on my Navigation screen. Although I like having my roof top clean I'll be moving that antenna once again.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
