Originally Posted by Big_Al1
lsd easier than oil change on the pumpmkin in middle of rear axle there are two plugs bottom to drain back to fill.Remove fill plug first would hate to get drain plug off and not be able to filler up drain out 3-4 qts raise driver side to get all of it out.Drop her down refill until it dribbles out of fill hole close it up and your done.75-90 royal purple works without and friction additives.Plugs I believe the only one that need changing are the v-6 something to do with emmision.
Sounds fairly easy.
Quick question though... I have an inclined driveway... and it would be a lot easier for me if I could do all the draining while my front wheels were just a little elevated on the driveway (wheels chocked of course)... but then I would have to roll it back down a little bit to refill it. I assume it's safe to roll it 5 feet without any oil in the differential, but I wanted to be sure.
Edit: Oh... and I assume all of this should be done with the differential is still warm...
