Re: Brake pads low... really?
You could probably replace them yourself.If they are actually low at 30k miles I would check and adjust the rear shoes I got 34k on mine and at last check mine were good the key is to adjust the rear shoes.This is so the front pads don't do all the braking and wear out prematully.But if you tow alot of heavy loads then they could be low I guess.
