Re: Prodigy P3 - doesn't turn off?
JJB:
Your brake controller is wired directly into the battery and bypasses the ignition switch. Think about it, would you want the brakes on your trailer NOT to work if you turned off the ignition or the truck started rolling without the key in it? The prodigy will turn off automatically after 15 to 30 min. and it will turn back on if you activate the brake pedal even with the ignition off.
