Old 05-11-2008, 10:42 AM
LifeTech's Avatar
LifeTech LifeTech is offline
Slummin'
LifeTech's Photo Albums
Last Online: 08-14-2008 09:17 AM
LifeTech is on a distinguished road.
Default Re: 08 Highlander Towing
Originally Posted by Mr Wayne View Post
FYI: Tow rating has nothing to do with engine size . The rating is based solely on suspension and BRAKING. They don't care how fast you can go, but how fast you can STOP
Actually this is not true.
For instance , the 1st Gen I-4 HL's have a lower cap. than a V6 HL of the same Gen. Toyota lables this difference on the OE hitch and accompanying Hitch manual.
Of course, susp. and braking are considered and used in the total equation as well.
I4-w/Tow prep>>3,000 pounds max. Gross weight capacity. 300lb. Tounge weight max.( the weight over the BALL/ Tounge)
V6-w/Tow prep>> 3,500 pounds max. Gross weight capacity. 350lb.
Tounge weight max.
Don't get confused with the max gross weight rating of the Hitch itself. It is a rating used by the Hitch Mfrs. before it is mounted on any Specific Vehicle. In this case, a Class II 2 inch sized reciever. On the 08 HL's the tow cap. is 5k and is considered a Class III 2 inch with this gross weight rating.
There are formulas used to derive these numbers.
LT
