Re: Installing Air Systems
I have to shoot a little WD40 in the fitting every 6 months to keep the little ball bearings moving, but it really doesn't fill up with road debris at all. Since you have a 2001 also, I think that plastic cover that sits on the transmission hump, just below the ash tray might be a good candidate for the gauge and switch. Other than that, I don't think we have many flat spots on the dash. There's that angled area to the left of the steering wheel, but you might need to fabricate an angled bracket so it would sit more at a 90 degree angle.
Mods: Mickey Thompson Classic II | Cornfed 2.5" Lift | Differential Drop Spacers | 930 Inner CV Boots | ProtechEZLift Limit Straps | Spintech Sportsman XL Muffler | Brembo Front Brake Rotors | A.R.E. Z-Series Cap w/ Thule Rack | Stubbs Rock Sliders | Hellwig Anti-Sway Bar | 285/75/16 BFG All Terrain TA KO's | VIAIR 400C Air Compressor w/ 2.5 gal tank | Front clear corner lamps | Odyssey PC1700T battery | Optima Red Top 75/35 battery (backup starter) | Hellroaring 95300A Isolator/Combiner | Truspeed Calibrator
