Re: Autozone brake pads
It's a definite no-no to reset the caliper pistons without cracking the bleeders open. Yes, most ABS units have screens, but the moisture that tends to accumulate in the caliper's piston bores will corrode the internals due to the DOT3 brake fluid's hygroscopic properties. Vacuum bleeding the old fluid is cheap insurance against brake system problems.
If your not cutting the rotors, it's a good idea to at least check the rotors for uneven wear and run-out and then, if it's all ok, rough up the rotor surface with some 120 grit sandpaper. This will enable the pads to seat quickly and give you better initial braking performance.
