Old 05-13-2008, 10:58 AM
slthomson slthomson is offline
Last Online: 06-03-2008 12:23 PM
slthomson is on a distinguished road.
slthomson's Photo Albums
Default Re: 2004 Sienna Right Side power door problem
I did some looking after some post on the siennaclub forum to further diagnose the problem. I believe both Motors are working properly. When the door close or open works properly, the door opens and shuts completely. So both the wench and soft close motors are working properly. I have now seen a couple of times where simply pulling the handle doesn't get the door lock mechanism to disengage and a soft tug on the door is required to get it going.
This leads to another question. Looking at the components diagram that was so generously provided, I think my problem is somewhere in the components associated with the Slide Door Lock mechanism. If the door button or handle is pulled in the case where it will not shut. The Motors try to close the door as you can see it move about a 1/8 of an inch and then when the lock doesn't release it stops. If I had to guess, I would guess the Slide Door Lock Actuator Assy or the Slide Door Full Open Stop Lock Assy. However, not having any experience with these mechanisms, I am asking any experts. With the description above to augment the initial description what would be your guess as the part to go after?
It occurs on both Open and Close consistently when using the button and intermittently using the door handle. In all cases the motors try to do their job, but when the door lock doesn't release, it stops. I have checked and rechecked the child safety lock and that does not appear to be the culprit. If it isn't the motors or the ECU, what could it be. I have tried the reset procedure a couple of times as well.
Any help would be appreciated. Attached is the pdfs supplied by other forum.
