Originally Posted by gregc
The system was intended to be driven at speed, on-road in 4WD so long as the diff is not locked.
You're fine.
-G
the sequoia's has a center diff lock. so when you engage the 4wd system without the center lock on, it's just like an AWD system.
Originally Posted by tinik
you should not use 4wd on pavement even if it rains (its only intended to be used off hard surface)you should not use 4wd on pavement even if it rains (its only intended to be used off hard surface)
the newer vehicles has a center lock diff. so when you don't engage that, it is just like having an AWD vehicle. some 4 runners are all time 4wd and they drive just fine.
