  #52 (permalink)
Old 05-14-2008, 08:27 AM
TundraBay's Avatar
TundraBay TundraBay is offline
Last Online: Today 08:00 AM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
Default Re: Get better fuel mileage guaranteed
Originally Posted by douglaspruitt View Post
If this worked Toyota would have already installed it on our trucks. No aftermarket fuel savers have ever worked.
Actually, that's not quite true. If you spend around $7,000 (the only semi-legitimate quote I've heard) you can get propane tanks, a fuel system, a new computer, and drilled out intake manifold ports, and some other stuff I forget, and you'll save gasoline. You will have to buy propane, though, and I haven't heard if they have the system for the new Tundra
[Tundra Bay]
Proud Member CBTMA
Radiant Red
