Re: DIY: All NAV Functions All The Time without Firmware Downgrade!
Joe B: you can't use the SPG to enable movies on the NAV while in motion. The SPG sends a pulse once every few seconds that equates to a 1 kmph speed which is just enough to unlock all of the NAV functions like address book, POI data, telephone dialing, etc., however the video input shuts off at the first sign of motion so it will "blink" on and off with each pulse. I may invent a second device to enable the video all the time however this is not a priority for me because I can already watch video in motion via my rear camera input hack.
Crewmadmax: you need to make sure you have an SPDT toggle switch and not one of those illuminated rocker switches like they use on fog lamps. Most of the illuminated rocker switches only have 3 pins and they use two of them to get ground and power for the illumination so they won't work properly with the speed pulse signals. On most SPDT toggle switches the center pin is common but sometimes it can be a side pin. Get the right switch from Radio Shack and then use the wiring diagram which I sent you to be sure that you are connecting the switch properly. You may also have to replace the IC chip inside your unit since you probably fried it by hooking it up wrong. This is cheap and easy: see the troubleshooting instructions which I included with the device.
WileETundra
view all of my 2007 Tundra mods and photos
