Old 05-15-2008, 03:45 AM
diablito1975 diablito1975 is offline
diablito1975's Photo Albums
Last Online: Today 03:13 AM
diablito1975 is on a distinguished road.
Default Re: ignition switch is messed up 02
Originally Posted by Computer Tech View Post
on my 02 trd tundra v8 when i try to start it the lock is kind of jammed up or its getting messed up. I am sure there is no pressure in the steering wheel where you have to turn it to remove pressure and then you can turn it, its not that. I have to kind of wiggle the key to get it to work. Anyone replace the switch??? how much dealer charged???
is it the ignition switch that is bad or the ignition lock cylinder?
both of them are eady to replace, you should do it your self and save some $$
ignition switch is the part at the bottom where the cylinder goes, it has the electrical contacts.$80 at dealer. parts only
ignition lock cylinder : where you insert your key.$90 at dealer. parts only. you will get a new separate key for you ignition lock.
