  #54 (permalink)
Old 05-15-2008, 09:21 AM
TundraBay's Avatar
TundraBay TundraBay is offline
Last Online: 11-16-2009 10:10 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
Default Re: Get better fuel mileage guaranteed
Originally Posted by jkd View Post
Yes, but unless those systems have become way more efficient recently, all through the years various engines running on propane got about 3 MPG less than it would on gasoline.
Rereading your post I see you're talking about adding propane to a gas engine, sorry I was referring to the 100% propane conversions. (Still can find how to delete a post here)
No you were right the first time. I don't think you can simultaneously supply gasoline and propane to the engine. Propane vehicle I drove before had two fuel systems, you could switch on the fly between. Propane was great if driving unloaded, mileage was similar or slightly worse but cost was about 2/3 of gas (the difference is bigger now). When towing, propane became much worse in terms of efficiency, so you'd switch back to gasoline.
[Tundra Bay]
Proud Member CBTMA
Radiant Red
