Thread: Question U bolt torque 2007 Tundra
Old 05-16-2008, 08:25 PM
Imdone's Avatar
Imdone Imdone is offline
My eBay Imdone's Photo Albums
Last Online: 11-28-2008 12:41 PM
Imdone is on a distinguished road.
Default Re: U bolt torque 2007 Tundra
Don't use pneumatics on it! That causes more damage than good. The only thing a big air gun is good for on a vehicle is REMOVING the lug nuts, not putting them back on.
98lbs is for the gen 1 trucks. I don't know if the bolts are larger on this truck or not, but a safe bet would be 115lbs with a torque wrench and then check after 25 miles.
I know the torque specs are around here somewhere.
edit:
SOS rear axle flip kit with new ubolts has torqe specs of 60lbs
RCD GEN1 double cab Ubolts torque specs are 85 - 100 lbs.
I would tighten to 90lbs and check after 100 miles and then again after 500 miles and if all is well, then you're good until you can find out for sure.
Work in progress...
