  #22 (permalink)
Old 05-19-2008, 04:38 PM
Skyhammerz Skyhammerz is offline
Last Online: 11-14-2009 03:13 PM
Skyhammerz is on a distinguished road.
Skyhammerz's Photo Albums
Default Re: Help me understand my traction control and VSC.
Since you have an 08, you have two choices when in A-LSD mode. When you first push the button to go into A-LSD mode, A-LSD and VSC are operating,(TRAC is disabled) so there is a possibility of the throttle being cut by VSC. Your second choice is to push and hold the button when in A-LSD mode, this turns off VSC and leaves you with just A-LSD operating with no throttle being cut.
In 4WD, VSC is disabled and you have A-TRAC, which is like A-LSD only it works on the front and back wheels.
If you do a search, you will find a couple of PDF files I have posted several times in different threads explaining how the traction control works on both the 07 and the 08.
2007 Tundra DC, 5.7, Limited, 4X4
TRD, NAV,TOW
Afe Stage 2
Xlerator Exhaust
Desert Sand Mica
