Re: Rock Sliders and Pro comp lift
Originally Posted by Toxarch
I understand what rock sliders are and know that they attach to the frame. Maybe I should rephrase the question. Do you have to drill the frame to mount these sliders or did they line up with any pre-existing holes? I'm guessing since they were not made for the Tundra then the frame had to be drilled.
oops sorry Tox. Yea, he probably had to drill some holes as the company he bought from doesn't sell them for Tundras. (as stated above)
My Truck: 2005 Tundra, 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP.  Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear] Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
