Re: 305 65 18 tires?
100% clear (leaves even more room than OEM)
will stick out 63 mm (2.5'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Wheelwells Will fill out the wheelwell by extra 19 mm. Make sure that you have enough room under the fender. If not, consider lower profiles or smaller rims.
