Originally Posted by heididog
OK, installed the airbags and tightened the u-bolts to 74 ft/lbs - seemed like it was about right as far as pull was concerned. For the heck of it I called my dealer and the service techasked a mechanic who came back with 52 ft/lbs. Great - Is the tech maybe talking about the driveshaft u-bolts (thats probably too high, eh?)
Does anyone have an 07 manual or is that where you got your info, Toxarch?
Thanks again.
Neil
which u-bolts are you talking about? the airbag u-bolt spec is in the instructions. if you removed the u-bolts that hold the axle to the leaf springs to take off the bump stops, i'd go with the spec a toyota mechanic cited for those.
