Re: MAF sensor
Take it out. There are usually 2 screws and an electrical connector. Using Electronic parts cleaner... GENTLY and I mean GENTLY spray the cleaner on and around the MAF sensor. You can also spray some down inside of it, but be cautioned......DO NOT USE A HARD SPRAY, just kind of mist it to wash any dust/debris there is inside of it. There are wires inside that can break if hit to hard with a spray pressure or air pressure. DO NOT USED COMPRESSED AIR TO DRY.. Let it air dry, will take less than 2 minutes to do so. RE-INSTALL and your done. Don't forget to plug it back in.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
