Old 05-27-2008, 01:31 PM
Sweet Mercy's Avatar
Sweet Mercy Sweet Mercy is offline
U didn't get an I-FORCE 5.7...
Sweet Mercy will become famous soon enough.
Sweet Mercy's Photo Albums My eBay
Default Re: Larger tires affecting shift points?
The way I understand is like this. Your computer is set from the factory with a specific size tire. Our trucks computers are not able to learn a new tire size without being calibrated for them. If you change tire size, whether bigger or smaller, the shiftpoint will remain calibrated for the stock tire, causing the truck to shift too soon if you went with larger tires or too late if you went to smaller tires. A small change in tire size probably doesn't effect it a lot. Again, that's the way I understand it.
Performance: Volant CAI; Classic Chambered Dual Exhaust--Powersticks
Exterior: Clear lens headlight covers; Westin side steps; Ventvisors-in channel, Spray in liner, Rancho shocks 9000xl front and rear, Silverstar high beams & fog lights, Polarg low beams, TRD oil cap, Chrome door handles, Limited outside mirrors, EGR bug shield, Remote start, TRD rear sway bar, TruXedo Tonneau, Grille overlay, 275/60 on Pro Comp 6066 20x8.5.
Interior: Opti Gauges, Limited instrument panel, Weathertech floor mats, Sport Pedals, auto-dim rear view and 35% side window tint.
CBTMA member
SEARCH FIRST
