Old 05-27-2008, 01:56 PM
THUNDERA's Avatar
THUNDERA THUNDERA is offline
Tire Roasting Member
Last Online: 11-20-2009 02:54 PM
THUNDERA is a splendid one to behold. THUNDERA is a splendid one to behold.
THUNDERA's Photo Albums
Default Re: Larger tires affecting shift points?
Originally Posted by eddiekidd View Post
The way I understand is like this. Your computer is set from the factory with a specific size tire. Our trucks computers are not able to learn a new tire size without being calibrated for them. If you change tire size, whether bigger or smaller, the shiftpoint will remain calibrated for the stock tire, causing the truck to shift too soon if you went with larger tires or too late if you went to smaller tires. A small change in tire size probably doesn't effect it a lot. Again, that's the way I understand it.
This is what I was thinking - but its backward. With larger diameter tires the ECU thinks the vehicle is moving slower than it actually is (if its reading the speed sensor). So if the wheels are actually rotating slower for a given speed wouldn't the ECU delay the shifts to compensate?
I have the 33" BFG's They are appox. 1.5" bigger than stock so I calculated that I am actually travelling 4% faster and farther than indicated.
Can the dealership re-calibrate for the tires? Or do I have to buy a tuner?
2007 Tundra DC Limited - Slate Metallic 5.7L 4WD
Red Rock Leather | Navigation | TRD Exhaust | TRD Sway Bar | TRD Supercharger | JBA Headers | URD MAF Calibrator w/ AFR Tune
ReadyLift 2.5" Front Spacers | 1" Rear Blocks |Pro Comp Front Coilovers | TRD Off-Road Package Springs | Bilstein Shocks | Pro Comp 6066 Wheels
BFG A/T KO 305/55R20 (33") |Bushwhacker Pocket Fender Flares (Color Keyed) | Escort SRX Radar Detection/Laser Defense System | Illumination by Hoen
- Coming Soon -
LED Tails | Tonneau Cover | Bed Divider | Rancho RS9000XL Shocks with in Cab Adjustibility | Pro Comp Traction Bars | Upgraded Stereo
