Old 05-27-2008, 03:04 PM
imjin's Avatar
imjin imjin is offline
ΜΟΛΩΝ ΛΑΒΕ
Last Online: Yesterday 10:04 PM
imjin is a splendid one to behold. imjin is a splendid one to behold. imjin is a splendid one to behold.
Send a message via AIM to imjin imjin's Photo Albums
Default Re: Larger tires affecting shift points?
That Hypertech module looks a whole lot easier to install than the Truspeed I did a few weeks ago. With the Truspeed you have to slave into the speed sensor wire behind the gauge cluster and solder it in place, but with this beauty, it's just plug in and go.
