Ok I just tried to take my non-DRL flasher out and I am confused.
Is the thing that J29 is connected to actually the flasher? IE the white box with the black cover on it? Or is the relay under that black cover? I got the black cover off with the connector still on and just saw what looked like silver wire loops inside the box.
If the larger white box IS actually the relay, how the heck do you get it out?
If it is NOT the relay, where is the actual relay? Is it the little black box that is above and to the left with a two wire black plug going into it?
Help!
EDIT
I found a picture of the relay in a different thread!
Adding DRL
