Re: DIY: How-To-Enable DRL – 2007 Tundra
One other question...I bought the relay socket you suggested and pins 87 and 86 are wired together between the two sockets (ie A-87 is wired to B-87 and same for the 86s)? Do I just cut those wires and redo it like the diagram shows?
EDIT
OK I figured this bit out...I just pulled the wires out, cut off the extra wires where the were hooked to the connector, and put the connectors into different spots, so where I have the no-connects I now have no wire at all to worry about. Just need to know where the actual flasher relay is by the main body ECU and I'll be good to go.
Matt
2008 Toyota Tundra || Salsa Red Pearl / Black|| 5.7 L V8 || TRD
