Re: DIY: How-To-Enable DRL – 2007 Tundra
Oops, noticed (I think) a typo in the document:
CAUTION!!!!!!!
Before you start make sure you do the following to isolate electrical
system components.
1. Disconnect the Negative Terminal from the Battery.
2. Find and Unplug Connectors J29 from the Main Body ECU
3. Find and Unplug Connector J3 from the Flasher Relay
4. Find and Unplug Connector A10 from behind the driver side headlight.
5. I strongly recommend that you solder all wire connections
Shouldn't Step 2 say J29 from the Flasher Relay, and Step 3 say J3 from the Main Body ECU?
Matt
2008 Toyota Tundra || Salsa Red Pearl / Black|| 5.7 L V8 || TRD
