Originally Posted by daless2
If I am not mistake there are two solar sensors, one on the drivers side and one of the passenger side.
As I read the tech manual, either of these is considered functional when they are applying 0.8 to 4.3 V, while light is shining on them.
Please check the PDF I posted above (Terminals of ECU, page #2) for the pin out for both of these sensors.
For $136 Each I’d make them myself given we know the specs and Radio Shack is right around the corner.
Frank
It seems as though there would be two sensors but I went to the dealer today and looked at a Limited and there is only one opto/thermo sensor on the drivers side and on my truck (SR5) there is a plastic cap covering up where the sensor would be....This is interesting, I do see on the ECU pinout where it shows a driver and passenger sensor and associated pin #s at J19-32 and J19-33 one for each for each and each has a GND return at J19-14..My guess is that the single sensor is actually a dual opto device remember it is not controlling the actual temperature of each side of the cabin.
