  #62 (permalink)
Old 05-30-2008, 10:01 PM
daless2's Avatar
daless2 daless2 is offline
Last Online: 08-07-2009 07:26 AM
daless2 will become famous soon enough.
daless2's Photo Albums
Default Re: DIY: How-To-Enable DRL – 2007 Tundra
Originally Posted by phobos512 View Post
Oops, noticed (I think) a typo in the document:
CAUTION!!!!!!!
Before you start make sure you do the following to isolate electrical
system components.
1. Disconnect the Negative Terminal from the Battery.
2. Find and Unplug Connectors J29 from the Main Body ECU
3. Find and Unplug Connector J3 from the Flasher Relay
4. Find and Unplug Connector A10 from behind the driver side headlight.
5. I strongly recommend that you solder all wire connections
Shouldn't Step 2 say J29 from the Flasher Relay, and Step 3 say J3 from the Main Body ECU?
Hi Matt,
You’re absolutely correct; I have that typo in the document. I am pursuing getting the original post updated with a new file that corrects this typo. In the mean time I will post the correct PDF below.
Also, I am posting a drawing that will explain how to remove the DRL / Flasher relay below.
Have a great evening,
Frank
DIY: How-To-Enable DRL – 2007 Tundra-drl-relay-removal.jpg
