Originally Posted by le franc
OK, I have a relay and lights on order as well. However, I prefer to use the stack, because the three dash switches are already occupied (thanks, rear heat, valet alarm disarm, and security system). I have searched and found a number of DIY turn signal stalk threads, so that is good. I alternatively could hide the security system indicator as it is not a switch, just an indicator light that the alarm is enabled.
However, it looks like there are two stalks options that have fog light capability, with or without auto light control.
By getting the stalk with auto light control for +$10, do I then magically enable auto light control too? Or are there other parts for that function that I just can't be enabled?
Regarding the switch...
Do yu have a switch
Blank by the
drivers right knee on the
lower dash next to the wip
er switch stalk? It is hard to see except when looking for it.
That is where I put my OE push button switch that was included with those
ebay lights.
This
blank would normaly be used for the
120V outlet power/on/off if so equipped. My switch just popped in no issues...but I use it to turn on my aux. driving lamps for my Safari light bar instead.
But then again...yu might just have this 120V switch in place?
LT
