Re: Which rotors to cure pulsating?
The term warping when applied to brake rotors tends to be a misnomer.
Sintered iron is inherently designed by its application NOT to warp.
What is occuring is called glazing buildup. It the exchange of material between pads and the rotors.
This will cause a Runout condition that many refer to as warping.
Also, as mentioned in above post indicates. One must always use a torque wrench to specs. when installing the lug nuts. This will assure an even load across the "torque ring" of each rim as it mates to the rotors surface. This will prevent any lateral run-out due to fitment installation.
LT
