Old 06-03-2008, 12:03 PM
mytundra's Avatar
mytundra mytundra is offline
mytundra's Photo Albums
Last Online: 11-16-2008 06:35 PM
mytundra is on a distinguished road.
Default Re: New CrewMax system
Originally Posted by jacahe View Post
Regarding your jl cleansweep...?
did you just run your fronts through it?
did you run your stock rears through it?
i am guessing your fronts bypass your original amp?
where is your sub amp or is your 450/4 amping your sub?
i am doing a similar setup with the jl 13tw5 sub... on the jl 500/1 and 450/4 for the doors... i like the box ... i am also guessing you are not willing to sacrifice leg room like me!!!!
I ran the feed to the summing unit from the front speakers. The rear speakers are still run by the factory amp, the front and sub are now run by the 450/4, and yes sacrificing leg room was a key consideration when we put this together as I did not want to turn the truck into a double cab.
2007 CrewMax Limited
