  #142 (permalink)
Old 06-04-2008, 11:20 PM
wileetundra's Avatar
wileetundra wileetundra is offline
Super Genius
Last Online: 11-03-2009 11:15 AM
wileetundra is on a distinguished road.
wileetundra's Photo Albums
Default Re: DIY: All NAV Functions All The Time without Firmware Downgrade!
Originally Posted by costanza2k1 View Post
In order to view DVDs from the stock RES on the stock NAV while in motion can the following be done:
1. put a switch on the speed sensor to shut it off
2. ground the parking break
When the Nav is needed again instead of the DVD flip the switch to off....thoughts would be greatly appreciated.
No, this won't work. When the speed pulse is missing or corrupt then the NAV resorts to using the GPS to monitor your speed. This is why king had to disconnect the GPS antenna, which will work if you also enable the speed pulse generator or disconnect the speed wire altogether, but I do not recommend this solution. The GPS antenna connector is not something you want to mess up and adding a switch or tap to that line could result in weaker GPS signal and poor performance from the NAV when you are not watching a DVD. Also, this will only work if you have the factory RSES package. I am still working on my second mod device to enable the video input all the time on all vehicles but it is second or third on the priority list right now. I am 90% of the way done, just need to do some more testing to confirm and then build a few prototypes.
WileETundra
view all of my 2007 Tundra mods and photos
