Originally Posted by imjin
OK, so I am getting ready to install the TruSpeed Recalibrator myself. In reading the factory directions, it tells you to go all the way back to the speed sensor itself (plugged into the back of the transfer case) and tie the TruSpeed Green/Yellow wires back at that location. The instructions shown here illustrates how you can tie into the appropriate wires (which I would guess would be the same wire) up by the combination meter behind the dash.
So, my first question is, the small blue box in the illustration above labeled "V2 Vehicle Speed Sensor (Combination Meter)" actually back at the trasfer case? Is there then no other connections or sensors tied into this wire between the speed sensor and the combination meter behind the dash? If this is the case then this seems to be a much better location to tie into the wires then in an area outside the cab more exposed to the elements.
Really, what I am asking is does the tie-in location described in these instructions allow the TruSpeed Recalibrator to correct not just the speedometer, but also the odometer, fuel delivery system, ABS function, etc.?
Thanks so much for any clarification.
And yes, well done on the instructions
mark
Oh, and I forgot, what is the single yellow wire shown leaving the speed sensor as shown in the illustration?
