Re: DIY: Camry 2.2L 2001 VSV for EGR Replacement
The EGR Modulator is located next to the EGR valve on the top of the intake manifold by the firewall, it has 3 vacuum lines going to it. Clean the vac lines and replace the modulator.
The EGR VSV is located on the back of the cylinder head under the intake manifold and is very difficult to access without raiing the vehicle.
PM me for more info.
25 yrs with TOYOTA
