Re: 2000 echo check engine light
The MAF is in the air filter box.
Yes AUtozone will usually read the codes.
We need a code to know which system is malfunctioning. There are over 300 things that will set a check engine light, so it's best not to guess or assume.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
