Re: DIY: Camry 2.2L 2001 VSV for EGR Replacement
Originally Posted by mdmm
Thanks alot.I will do it tomorow.Today morning i got the light back and am getting three previous codes, PO441,PO446,Po401.
I saw a sonsor behibd EGR valve in my Camry2000.It say"" Toyota , Sensory Assay , VAC, 89420-060 40 and at the bottom is a number, 0136 .
Please let me know what is this sensor about and Do I need to clean it or replace it also if it may be causing the problem ???
That should be the EGR modulator, check it. It either passes or fails. Usually they need to be replaced along with the EGR VSV under the intake manifold.
25 yrs with TOYOTA
