Old 06-17-2008, 03:09 PM
D&DS D&DS is offline
D&DS's Photo Albums
Last Online: 07-17-2008 03:42 PM
D&DS is on a distinguished road.
Default Re: 1998 Camry 4 cyl. Stall problem when Hot
I didn’t see fuel pumps mentioned.
... Most modern vehicles are equipped with an electric fuel pump mounted in the fuel tank. Some have ‘self cleaning filters' that can temporarily clog up with accumulated debris. When the vehicle is idling the supplied voltage to the pump may be lower and a weak pump might not be putting out quite enough pressure.
... If you are running a 10 million watt audio system it may be dragging current from the pump… you might try turning it off… it may help the pump and maybe I can get some sleep!
Have a good one while you can still laugh about it.. Don S..
Why did the U.S Government remove food and fuel from the inflation rate?... It sounds better at 4% … I think some of us know better!…
'08 Camry LE 2.4 - '04 Sentra LS 1.8 - '99 Frontier KC 3.3 4x4 - '76 Wagoneer 6.6 4x4
