  #27 (permalink)
Old 06-21-2008, 02:40 PM
123Gone's Avatar
123Gone 123Gone is offline
123Gone's Photo Albums
Last Online: Yesterday 10:06 AM
123Gone is on a distinguished road.
Default Re: Rhino-Liner vs. Speedliner opinions (No Line-x)
I've never used POR-15 products but it's my understanding that they are VERY good.
Well, I think the closest POR-15 product to a bedliner would be BlackCoat. If you use this, I think you are going to run into some problems:
1. How are you going to apply a non-slip final texture?
2. BlackCoat cost about $165 per gallon. BlackCoat is almost 30% solvents (that evaporate away) which means that per every gallon, you only end up with about 3/4 of a gallon of actual solids. When we apply a bedliner, we spray in about 4 to 4.5 gallons of solvent free solids which ends up as a thickness of about 3/16" on the bed and about 1/8" on the sides. To get the same thickness out of BlackCoat, you would have to buy about 5 or 6 gallons of BlackCoat which would cost you $825 to $990.
3. In order to apply BlackCoat, you will also need to prep the bed. You will need, paper, tape, acetone, gloves, brushes/roller, POR-15 solvent (for thinning and clean up), and probably a day or two of your time.
