Originally Posted by THUNDERA
A couple more speaking points for everyone to chew on...
1) What fluid are we to fill the intercooler core with? Water? Any other additives suggested to increase the heat capacity? Or is it just regular coolant?
we fill ours with the Toyota coolant that is run in the cooling system on the truck.
2) For those of us going to the SC and have an intake installed we are going to have to reinstall the factory airbox and filter. It's probably recommended that we have the TRD panel air filter, right? I noticed that these are oiled, is this going to cause a problem?
re-install the lower part with the new air inlet, it comes with the TRD panel filter in the fit kit. It is an oiled filter but not "over "oiled, if you know what im saying. to much oil is where everyone is messing up the MAF sensor.
so no problems are fore seen.
Mark
