Re: 19.8mpg after HC removed!
Removed mine and did the battery reset, haven't tested for fuel economy improvement yet. The filter will need double sided tape to stay in place again if I need to put it back. Throttle response is marginally improved, and the high idle on start up seems to be diminished a little.
If fuel economy improves I will be doing the same thing to the wife's car. It too has a HC filter in the air box, and it will be coming out if this works on the truck.
