Re: Myrtle Beach Meet - June 21st, 2008
Originally Posted by ERik
If your a payed member like myself you get Unlimited photo access on Ts .Some problem i've ran into is higher res camera esp sano cam on bulk load's tend to kick you from uploading on Ts thus you have to do 3 or 4 pictures in order for that to process..
That's because the forum resizes hi-res photos down to 1024x768 or 1200x800 max res (I forget which one). If you resize to 1024x768 prior to uploading, you can process 15 at a time. Otherwise, you get kicked back like you mentioned.
My Truck: 2005 Tundra, 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP.  Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear] Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
