Originally Posted by mustang67408
Here is a PDF that will help you test the inner workings of the door lock system. There is a unlock switch on the back of the drivers cylinder and key and a micro switch in the latch mechanism. You may or may not have the switch on the key portion, due to the fact you dont have the factory alarm.
Use the PDF's as a guide.
Since it wont unlock or lock with the key, that tells me there is something wrong with the latch mechanism, and that would be the first place to start.
Hello,
Would you mind sending me a copy of the PDF file? I have problem with the power locks of my '96 camry DX.
Driver's side will lock all doors but will not unlock them. The indoor lock button does not work for unlock once the doors are closed (I tried it with the window down). Actually, neither the lock key nor the indoor button will unlock the car once the dome light door switch turns the light off. The circuit seems dead
AS for the passenger side, the door key lock unlocks all doors. However, if you try the indoor button it will not unlock unless you first operate the door's own manual lock; if you do that then the system gets energized and both indoor buttons will work.
I can figure out testing procedures but without a wiring scheme I am pretty much lost. Any help will be appreciated.
Thanks
