Re: Proposed Group Buy: Unichip P&P Tuner For 07+ Tundra & All Toyo Trucks & Suvs
Originally Posted by 07bsmcrewmax
ok, so let me get this right...
1. when we order the chips we must tell them what mods we have Yes, they will pre-load the map to the chip
2. the chips will come pre-programed Yes, with a harness that allows you to connect the chip to the ECU.
since it is programmed is it just a plug in installation or do we need to have it installed by a dealer or need a special computer program?
Sorry you guys are having to spell this out, im illiterate when it comes to this sort of stuff.
It's a Plug-n-play harness. I have the 2003 version and it required me to remove my glovebox door (two screws) and the back of the glovebox (three screws). The vehicle wiring attaches to the ECU with plugs, with a release latch on top. Each plug is a different size so they can only fit one way, one place. The plugs from the vehicle are plugged into the Unichip harness adapter and it's wires plug into the ECU, same style plugs that only fit one way/one place and they are all labled as to where to plug it. It is that simple.
BJ
2003 Tundra 4.7L V8 Access Cab Limited 4WD w/ all factory packages, Black Onyx 202-rebadged. was stock 31K on 5/9/05, now 56K
Performance: DYNOed at 208 HP and 272 TQ * UNICHIP (broken) * AEM Brute Force Intake * AEM DryFlow Filter * K&N DryCharger * AirRaid TBS * JBA Titanium-Ceramic Headers * JBA Y-Pipe * Gibson CAT-Back Dual Extreme Exhaust * PulseStar Pulse Plugs * Fitch Fuel Catalyst System * Optima D35 Yellow Top * Argus Battery Bug * Fumoto F103N Oil Drain Valve * RP Oils * Exterior: * Extang Full-Tilt Tonneau * Bedrug * Topline Tailgate Step * Mr. Gille Upper & Lower Billet Grille * WAAG Bumper Guards, front & rear * HT Side Step Nerf Bars * AVS Hood Protector * WeatherTech Vent Shades * JDM Black Taillights * TurnSmart Solar-power Mirror Turn-Signals * Altec 48" Line-of-Fire LED Light Kit * Altec 53" Screamer Amber Side Marker LED * PIAA Backup/Work Lights * 35 % Tinting * Bully LED Third Brake/Cargo Light * Interior: * Gentex Auto Dimming Compass/Temp Rear View * Garmin's Nuvi 660 GPS * Scan Guage II * Passport SR7 Radar/laser shifter * Wheels/Tires: * Moto Metal M0951 Gloss Black 17 in. Alloys * SpiderTrax 1.25" Wheel Spacers * Goodyear Fortera TripleTred radials P275/60R17 * Suspension: * Bilstein HD Shocks, F&R * Hellwig Rear Sway Bar & Helper Springs * TCS Poly Steering Rack Bushings * Wheeler's Front Sway Bar Bushings * Timbren SES Kit, Front & Rear * Brakes: * TRD Big Brake Kit (front) *
BAD BONEZ BJ
