Re: Toyota Yaris 2007 Auto engine noise also where is the transmission fluid?
Hummmmmmmm...........Name calling?.......now that is soooooo mature.
I don't have ANY degrees at all , but if any engine I have has to operate in any condition that I feel is stressful as in heat/rpm/towing/working..........I put in a slightly heavier blend........but it is hot down here. I have had no engine at all seize/throw a rod/burn a bearing............and I ran the sh-t out of a 20r on 20-50 castrol for 350,000 miles.............valve seals would smoke alittle after an idle.......and I drove it with the pedal on the floor. After 3500 miles I was a 1/2 qt low............
