Old 06-30-2008, 02:25 PM
05Moose's Avatar
05Moose 05Moose is offline
05Moose's Photo Albums
Last Online: Today 08:42 PM
05Moose is on a distinguished road.
Default Re: Front Rotor Removal
I guess I should update this one too (as I did on the other forum). Yes, I was able to take the rotor off easily enough once I found the correct size bolt (easier to run the bolt thru the front as intended to remove these than to use a hammer). But then I didn't take them in because I found stress fractures running perpendicular along the rotor surface just above where the center veins were running. Took it in this morning and sure enough they both have fractures all over them.
So, keep an eye out on those front rotors.
"It's not what you know. It's knowing where to find the answer."
'05 4x4 DC LB SR5 Tow Pkg BFG All-Terrain T/A KO, Leer Tonneau, Westin Platinum Nerf Bars, Fog Light Mod, Orig. Owner 12/3/04
